It's involved, but not impossible. It will require hybridding either the nissan stanza or maxima's gear boxes and getting custom axles made. The result, the much needed limit slip differential and the gear ratio of a bigger/heavier more powerful car. Now, since my little engine puts out nearly 3x the power of the maxima with less weight, let's just say I go pretty fast in style
. Time, money, patience and resources would be needed to effectuate this set-up. The donors: 1991-94 nissan maxima SE with locking differental and the 1990-92 nissan stanza SE with locking differential. The stanza has the longer gears as you guys can see in some of my old dyno pulls (if you can find them). Third gear yield me around 119mph (no speedo error) and let's not even go into 5th gear which delivered speeds upwards of 150+mph. So you have the gears of the maxima and/or stanza, more power and less weight which equals rediculousness. I have something wonderful coming out soon for the FWD and RWD guys on the CA platform, so you guys stay tuned. I'm a "No limit soldier" with the CA, but time owns me.
