FWD to RWD swapping of IAC valve
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
I have been doing a fair amount of checking with little luck on this. I have a problem with my IAC valve on my S13 RWD engine and i wanted to know if anyone out there has tried this or not. I wanted to know if the FWD SR engines turboed and N/A have the same IAC valve. IAC stands for (Idle Air Control) for those of you who dont know.I work at a nissan dealership and have access to the parts department parts lookup equipment but the pics are less than perfect to get a good idea. I am sure the housing are going to be very close but i am not sure about the electronics. The nice thing is the electronics are removable and if the housings are off but the electronics are the same i can make a good IAC that will work simply by swapping the electronics to the older housing. So if anyone has some info on this kindly let me know. CAR IS RUNNING LIKE TOTAL CRAP RIGHT NOW!
Thanx
Mark
S14-NEO
anybody?????
180fan
Car: 89 fastback
I doubt the NA one will work with the rwd model.
S14-NEO
man thats not what i wanted to hear..
stiergott
Car: 240
generally speaking if you take the iacv off and clean it real good you wont need another one.
180fan
Car: 89 fastback
S14MARKSR wrote:man thats not what i wanted to hear..
Yeah I'm fairly certain there's no US replacement for the IACV. You can probably get one cheap from someone like Marco or Venus.
dsm007
Car: 1995 nissan 240sx SE
stiergott wrote:generally speaking if you take the iacv off and clean it real good you wont need another one.
I think Mark has tried like 3 times to clean it with ill results.....seems like once these things go its done for.
stiergott
Car: 240
spraying carb cleaner down the big tube or in the wee hole arent going to cut it. you have to take it off the manifold, take the iacv all the way apart, clean all the individual bits, and then put it all back together and reinstall it.
S14-NEO
been there done that...just spraying carb cleaner wont do diddly, not that i have done that but trust me i KNOW better. the entire thing has been pulled apart and completely cleaned . both of the plungers , the springs, the casing...the whole nine.
travisn
dude thats ****ty, you work at a dealer ship and need to ask questions... shame shame, if you already have it off your car have parts get you one from the na sr and compare. wont cost you a dime... kids these days
nismotuner82
Well you know what I think is *****y is that you are being a prick to a fellow NICO member. Jeez what happend to this place. Take you sarcasim back to NY buddy, as this thread was posted correctly, and we are looking for a solution.
Cory
