nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed Jul 19, 2006 5:56 pm
1. If it's got an AWD transmission, I suspect it's a GTi-R motor (though that's not necessarily true), in which case it's built quite stoutly. The easiest way to tell will be the head, as it will have solid rather than hydraulic lifters. Otherwise I don't think there's much of a difference in bottom end strengths.
2. SR20DET
3. GTi-R, and I do believe there were AWD Bluebird DETs as well. edit: RED got this bit.
4. Without turbo, $500-750 I suspect. Stock non-GTi-R DETs go for roughly $1k or a nudge over that with the turbo and such.
5. An AWD transmission would be larger and have a housing extending back into the tunnel that any USDM Sentra/200SX/G20 won't have. If it has an AWD transmission, start pulling that sucker off and find yourself a B15 LSD FWD transmission, there is not a single known AWD-converted USDM Sentra even amongst the handful of deep-pockets that care.
