float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue May 17, 2005 4:03 am
I honestly still think that 20% is pretty high. Here's a little math off the top of my head...engine makes 400 horsepower and you get 300 of that to the ground. That means that you are loosing 100hp to "drivetrain losses". Each horsepower is about 3/4 of a Kilowatt. So 100 hp is approx 75 Kilowatts. Now lets say we run the motor, at that figure, for one hour. We now have released 75KW-Hour's of energy. That is the equivilent of approx. 64,500,000 calories of energy. Now if we take a transmission and over-figure, and say that it has 100lbs of aluminum in it (if it was less, this would be even worse) we can convert 100lbs of aluminum to approx 45,300grams of aluminum. The specif heat,defined as (cal/g oC) of Aluminum is 0.215. That number basically tells us how much energy has to be put into 1gram of aluminum to get it to change one degree Celcius. So using the numbers we've come up with so far, the Aluminum's temperature would raise approx 1,400 degrees celcius. The melting point of Aluminum is about 660 degrees celcius. Granted that we would have to run the engine for one hour for this to happen. But even at half and hour, the temperature will raise 700degrees. And to be honest, i've rounded all of these numbers down, so they are all actually lower than what they would be. Just something to think about...
