fwd ca18det
1SlowCA18DET
is it possible to use a fwd ca18det motor in a 240sx??? I was told that the bolt patterns on the bell housings are the same, but im not sure about the motor mounts
boost_boy
1SlowCA18DET wrote:is it possible to use a fwd ca18det motor in a 240sx??? I was told that the bolt patterns on the bell housings are the same, but im not sure about the motor mounts
You can, but you need to make minor modifications to the intake, water supplies, blah-blah. the engine inour white sentra is RWD one converted to FWD, so it is very doable.
Dee
themadscientist
I can maybe find a RWD intake still so you don't have to fab one or put the throttle on backwards.
