i have posted a few times regarding a CA18DET into B12 sentra swap. I've been sitting on a U12 TMIC CA18det engine (i think its the Mark II U12 motor right?), KN13 CA18DE trans, and ECU/harness from an s13 for a while, wanting to swap them into my 89 B12 sedan.
engine not so pretty haha...
However i couldn't find any of the intermediate parts i needed (from a KN13 Pulsar SE)
So, my plan for a while was to find a wrecked KN13 SE when I got my tax return.
Finally, that is done! I found a 5 speed 88 Pulsar NX SE in Oregon, and got it shipped here (not cheap haha...)
The KN13 isn't even wrecked (although there is a small amount of passenger side front fender damage) and it even starts and drives!(it does have a blown head gasket, and boy you can tell) However, seeing as my new KN13 "parts car" is much rarer, and in some ways nicer than my daily driven B12 (less miles, less body damage, paint in better condition, etc), and since I could perform the swap into the already-CA18DE equipped car with less work and less moving around of all the damn parts in the engine bay, i've decided to change my project from B12 CA18DET to KN13 CA18DET. Also it helps that i can keep my B12 running this way (as i dont have a second currently running car, that is kinda necessary haha...)
So, to come to my questions, I have found from searching through the web CA18DET muck that I can use the DE cars harness with the DET, as long as I add 10 ohm resistors before the injector plugs on the harness? Is this true? It seems too easy, it seems like there might be more sensors on the DET, or something I would have to add. Anybody got any insight into this? I have emailed Dee a few times, and Stephen as they are FWD DET experts, (you guys are awesome and have been incredibly helpful, thank you thank you!). Also I know there are a couple people with DET swapped Pulsar SE's (livlyjay, liquidneon, etc), so i'm hoping one of you will lend me access to your brain of knowledge
I also understand the ca18de ECU will not safely run the DET, so I have been trying to figure out what to do about engine management. My budget is not enough to cover a $1k+ haltech or SDS standalone, but I have been looking into having my CA18DE Pulsars ECU sent to JWT and eprommed to run the CA18DET. That would only be $600, way off from $1500 for the SDS. Obviously I would love the ability to self tune for more fuel and boost further down the line, but as of now my budget is not quite big enough to start rebuilding the engine and adding extra parts, so I plan on running stock boost for a little anyways. Also, JWT said they can retune the ECU for more boost/fuel for only $100 (although I do have to send it back to them, obviously)
I know Dee has had bad experiences with his DETs being run by JWT, but the posts he refers to that in are anywhere from 9 to 5 years old, so I think they may be better at tuning the DET now than in the past. Anybody else had experiences with JWT DET ecus?
A few more questions. Do any of you DET equipped pulsar guys have problems passing emissions? In AZ they only do a half assed visual inspection and a sniffer test, so I figure as long as its running a proper air fuel ratio with a new cat it should pass just fine
And finally, does the U12 motor really bolt directly in with all the brackets and mounts from the Pulsar DE engine? Is there anything I need to source from another car? I would really like to start my swap as I think i finally have all the needed parts to get the engine physically into the car, but I want to make sure I have every needed part and resource so I can not have a half-disassembled car sitting in my drive way for 6 months (long enough to forget where all your plugs, hoses, etc go when you're done haha)
Thanks if you bothered to read the whole thing, I know its long haha.
-Conley
i think its an idle control or something, does anyone have the real name of it or a part number?
