That will work, Ez out can work. No matter which you use, be very very carefull! The problem with taking them out seems to be that the first couple of threads get damaged when the studs are bottomed out. Therefore when you are removing them, you have to work through all of that mess.dsc4130 wrote:How did you all get the broken studs out? The RB I just got has 3 studs already broken inside of the head. Just use a reverse threaded bit?
