i have the ultimate and I like it. Next best thing to a standalone if you know how to use it.
I would trust it up to the 400whp range.
Pluses: Timing adjustments Can handle 1000cc injectors Tuned specially for your setup Can keep your stock mafs if you buy a map sensor Can datalog timing, rpm, afr, knock, water temp, inj duty cycle, + more, all in real time.
cons: Not plug and play Wiring diagram suplied is wrong and won't allow you to datalog timing, but can be fixed easily. Low support
Just make sure if you get the emu you get all the supporting harnesses, they make tuning much easier. If you do go this route and have any questions just email me at
[email protected]. Aceinhole is also very helpful and knowledgeable about the emu
