hazeyisrxllin wrote:On a side note the les grossman avi is awesome lol ...maybe initial I'll go for a bassicly stock set up with upgraded turbos better intercoolers better injectors and better brakes and then build up further from there
I started here because this is the best plan for you^^^, and will be about 10 grand in parts and labor unless you can do the engine work yourself which could save about 40-50% costs that you can use for those GTR Brembos you mentioned and anything else for the swap such as ECU/AFC tuning needs or other things (rad, any other misc. you can't swap from your TT).
If you look at my build that's my basic path I took, although I had it done by a Z pro...plus had the ECU change and the Apexi AFC added which you would need to make the injectors and rest of turbo setup work. Hopefully any savings from doing your own labor could be used for extras...of which there are many and will cost you time figuring out and locating id you are not already dealing with those Z32 vendors and people-in-the-know.
As "Les Grossman" mentioned, this is where the lost time and frustration comes in...
Good luck!!
