Future FX35 owner?
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
VikingGuy
Hello all. This is the first time I've been here and it looks like a great site. I'm seriously looking at the FX35 (AWD) for my next vehicle and am planning on driving a few this coming weekend. My budget limits me to the 2005-06 models, but I still think these years offer quite a bit of bang for the buck compared to other models in the same class. I've done a lot of research on them but am wondering if there's anything I should be keeping an eye out for when I test drive them. Are there any issues that are common with the FX35? Also, are there certain mileage marks (expensive service intervals) I should be aware of? For example, I'm a long time Audi owner and know that the timing belt/water pump change on Audis is extremely expensive and very common. Thanks for the info.
VikingGuy
I've heard that the dash bubbling up is a common issue. Some people are saying its only on the black/charcoal colored dashes. Does anyone know if this is true?
jimmy-j
you don't have to worry about the timing belt as the cams are on a chain.. you'll need to do regular drive belt checkups though as those are still rubber.
08blackG35sedan
Car: 2008 G35 sedan
Go with the '06 over the '05. The '06's and up got a revised interior that is much improved!
Chris92SE
Car: 2017 Infiniti QX30
2003 Nissan Pathfinder LE
I bought an 05, but around here all of the 06s were several thousand more, even with more miles. Mine is not the sport model and it does not have navi. I think all of the 06+ models come with navi. That might be the reason mine was less expensive than most of the others I found.
I do think the 06 interior looks better, but I am fine with the 05 version. I am not that much of a navigation user, so that didn't worry me, either.
I am a bit concerned about the dash, so I have been using a silver shade on it and it stays in the garage at home when not being used. Luckily, my wife works evenings, so the car spends a lot of time during the day in the garage.
Good luck with your search.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
