FUSES M35 2007
Larz
Car: 2019 Q70-L RWD
Whiler changing my interior dome lamps, I must have bown a fuse. My driver seat, and interior lights do not work. Any idea which fuse I blew? or which fuse box to look at?
I have a service manual (disc) that shows where the different fuse boxes are located, but that doesn't include a description of what each fuse relates to. I'm trying to avoid looking at each fuse one by one to see which one went titz-up.
Any help would be appreciated, Thanks
Larz
Car: 2019 Q70-L RWD
OK so after spending considerable time with my owner's manual (no help) and my service manual disc I found my answer. I'm posting it in case oyu lot have this same issue with interior lights.
The location of the fuse box for all the interior lights and switches is located on the side wall of the driverside near the bottom right next to the parking brake. Once you open the little compartment there is a diagram that shows you what every fuse is for.
