Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Thu Apr 16, 2009 5:32 am
Did the air mix door issue and the fuse issue start at exactly the same time? Do you have any aftermarket accessories wired in to your electrical system? In most cases a recent change in something will cause the problem...
One of the few times I was stranded on the side of the road, was after I installed an aftermarket CD changer. I used a "eurostyle" terminal strip with recessed heads for the power, but it still found a way to short... The good news was that I was stranded near the air national guard base, and I had a cool air show to watch until help arrived
Does that fuse have anything to do with your brake lights or tail lights? If so, overheating and corrosion in the sockets is pretty common, so that would be the first place to check.
Good luck!
Heath
