fuse panel/cabin air filtration unit behind glovebox? how to access?
neagan
Car: 2002 Q45 * 2001 QX4* 2008 G37* 1988 IROC* 1941 Dodge Army Trux* Racecars
How do I remove the glovebox to access these two areas? Nitro
NISTECH
the fuse panel is behind the small compartment to the left and down of the steering wheel.
The glove box is removed by taking the 4 phillips screws along the top and the 2 or 3 at the bottom of the panel around the glove box.
neagan
Thanks for coming through with an answer . I know about the fuse panel by the drivers side, but I've seen a couple times that there's also supposed to be one behind the glovebox. Hmmm. There's Always more to learn!!!! Nitro
NISTECH
nah the other fuse panel is under the hood.
