Fuse location
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Q56owner
Car: 2010 QX56
My dash lights on the temperature, radio etc. aren't working, the fuse covers, or the owners manual don't really show which fuse is which, anyone know the location for the illumination lights fuse? The dimmer works on the gauges , but I have no lights on the rest of the dash at night, thanks.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Probably the tail light fuse, if it's anything like a Pathfinder.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
I am pretty sure it had the fuses listed in the owner's manual, but it should be one of the fuses located in the passenger compartment. If nothing else, I know the FSM will have the location listed. Here is a link for you:
http://www.nicoclub.com/FSM/QX56/2010/
Q56owner
Car: 2010 QX56
Actually the owners manual doesn't list specific fuses, I finally found it the old fashion way, removing each one and checking them visually, and I did find it under the hood, in the rear fuse box, one of the ones going vertically in the panel, it was a 10 amp, and everything works good now. I should of taken a picture of it, but I didn't, thanks for the comeback, and have a good holiday.
Timmbo
Same to you, Merry Christmas!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
