*itch post what car you have next time, I had to check your previous posts to confirm my suspissions.. Luckilly you only have 9, and I was correct in my assesment in that it is the s14b
Do me a favor and check the harness after the injectors where it runs under the breather tube, and towards the front of the head...
Almost spot on positive its resting on the bolt in the head and has eaten through the harness and nailed blk/r.... or the primary ignition wire... Youll see arc marks on the bolt and the harness will be worn through...
I learned the hard way and tested EVERYTHING before finding it, and had to have my car towed for the first and only time the night before...
If you are uncomfortable with electrical email me as you are local and I am free tommorow...
Also post if I am correct, and Ill tell you how to fix it 100%...
Funny thing is mine did the same at about the same miles give or take 1 - 5 thousand...
Edit: DONT EVER JUMP A FUSE WITH SOMETHING NONFUSABLE AGAIN.... HOPEFULLY YOU DIDNT **** ANYTHING UP TOO MUCH BY DOING THAT......
oh yeah and iirc after I did this I found out there was a tsb (from another didnt actually see it though I could check) out for this problem as well.
