sbird1 »
https://forums.nicoclub.com/sbird1-u34133.html
Sun Aug 28, 2011 6:23 pm
The fuse connects a circuit. The wire coming into that fuse is carrying too much current. You're going to have to trace the wire. Follow where ever the wire goes. If it splits, follow each of those. You should be able to look up what the proper level of current is supposed to be traveling through the wire. You already know that the wire coming into the fuse is hot (carrying too much current) so at some point, there's going to be a point where at one part of the wire, the current is correct, and further down the current is too high. Find that point, and you should be able to see if there is a problem with the wiring. Most likely it's going to be a bad ground, a wire with the sheathing melted off or something. There is a physical fault in the wire somewhere. You just need to find out where. Hope that helps...
