luna11 »
https://forums.nicoclub.com/luna11-u11585.html
Thu Jan 12, 2006 9:15 am
Well thanks everyone for all the help, but...1. i never found the fuse,2.i didn't have to take off the steering wheel center area to get to the switch....BUT...the cruise is fixed!...It seems that since the button on the left side of driver would light up, and only the cruise button on the steering wheel would not engage or light up on the dash (green light)..i started thinking about the fact that maybe it might have something to do with the "cruise switch" under the brake pedal...right next to the brake light switch that controls the brake lights....Sure enough...(and this may account for several others cruise control malfunctions)...the small "stop pad" that presses the switch in and shuts off the brake lights had been replaced with a bolt and nut!!!! when this happened, the brake lights worked, BUT because it was thicker than the actual rubber pads that are usually in there it did not allow the cruise switch to activate...also it's pad was missing....once they were both replaced and adjusted properly, all functioned perfectly....So the convertible is cruisin' again, like new!!!!!It is however a pain to get to, and you may end up saying some bad words, but it was a cheap repair!!!!!
