fuse box
Forum for the unique Murano, and official home of Nissan Murano Club!
parkitos
Car: nissan Murano 2005 & z350 2005
I have a nissan Murano 2005 awd and the problem i have is that none of my inside lights work (map lights, center light, door lights, inner trunk lights, etc) what can i do??????
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
parkitos wrote:I have a nissan Murano 2005 awd and the problem i have is that none of my inside lights work (map lights, center light, door lights, inner trunk lights, etc) what can i do??????
Welcome to NICOclub! Thanks for visiting the Murano Forum!
Did you check the fuses inside the cabin? I am not sure of this, but on my Armada there is a second fuse box under the hood, that may be the case with your Murano as well. Let me know if that helps!
parkitos
Yes there is a case under the hood, but do you know which is the fuse I should change????
Timmbo
It should say on the plastic cover what each fuse controls.
saudler
Car: 2003 murano
I am having the same problem with my 2003 murano and its not in any of the three fuse panels one under the dash the two under the hood let me know if you have any luck with this problem
driver13
Car: 03 Murano
I have the same problem on my '03. Checked the fuses and bulbs with a meter and nothing found. Anyone find a solution to the interior lights all not working?
Return to “Murano Forum”
