Postby Johnnydangerus » Thu Dec 10, 2020 5:12 pm
The box seems to open upside down to me. Had to fidget around and remove box from mount in order to remove cover. Easier to put back on exactly same as I took off. The pinched wires are to a relay which is inside but separate from the board? Wires look fine from outside. On the othe side are wires directly wired into circuit coming from firewall (also pinched in bracket or mount), one is orange seen in photo. I just found out I have remote start when receving the spares by mail so not sure if these wires could be to that or hdi headlights? And if so would it be stock set up or aftermarket if hdi? I believe the remote start is aftermarket because I have fortin evo fobs also.
- Fuse box #1 Fuses
