Fuse Blowing Installing HID kit
zin1904
Car: 07 G35 Coupe/01 Pathfinder 4WD
So I ordered an hid conversion kit from simplyhidkits.com with the slim ballast.
It seemed to be a pretty easy install, out with the old in with the new plug and play. For some reason my headlamp fuse for the passenger side keeps getting blown. I've gone through 10 15A fuses doing trial and error and eventually gave up and installed brand new halogen lights back in it.
Anyone come across this or know why my fuse keeps blowing?
BoostMyQX4
Car: 96 Infiniti QX4
Use a relay harness kit man, this way the ballast will be pulling power straight from the battery instead of your headlight harness.
Here is your linky
zin1904
sweet thanks Boost! I will be ordering this and installing as soon as it comes in! thanks again
Casutherland42
Car: 2000 Nissan Pathfinder
I went through this exact same issue, with the same headlight going out over and over. Eventually gave up. Took it to the dealership today, and they also told me that the wiring harness was melting as well. He said that nissans just stuggle with HID kits. He told me that he had to remove them from his car and he has a relay harness kit that hooked straight to the battery as well.
zin1904
I'll be getting my relay in tomorrow and I will be trying this HID conversion again this weekend. Then soon after that I will be that jerk on the road with bright a** lights flashing in your rear view mirror. haha
Casutherland42
Ya my dealer said that the relay take power from the wiring harness inside the car, but not heat. He said it could melt the wiring harness, (happened to his nissan maxima) and cost up to $800 to replace. Not worth that to me.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
I've sold countless of HID kits and Nissan usually are trouble free
relay kits can help, but usually if the kit is blowing fuses consistently there is a problem with the ballast usually. Never upgrade the fuses more than a few amps to solve a HID fuse blowing issue or you often will create a larger issue
I have never seen a HID kit damage the factory harness unless it completely fails and heats up. I don't buy what the dealer says, nor would I agree that Nissans are more prone to trouble.
What I mean to say is don't chalk up the the issues to the car being a Nissan, hold the HID seller accountable if you keep having problems after the relay kit
Casutherland42
This may be a biased answer lol, but where do you recommend purchasing them at?
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
If possible I'd say buy from a local shop, one with a good reputation and will warranty should anything go wrong.
eBay is a nightmare, after 60 days it's often very difficult to get sellers to warranty defects.
To be 100% honest the quality of HID kits has dropped a lot and even when you pay more for a kit from a online vendor who says their kit is 'Japanese' or 'German' often it's the same as a much cheaper kit.
Casutherland42
I bought these. High price, but this website is reputable..
http://www.kbcarstuff.com/Volt-HID-Digi ... dp-hid.htm
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
service is the most important, I know where those HIDs come from, but say you pay $60 somewhere else and you have a warranty issue that goes unresolved, you quickly end up spending more than you paid at kbb!
