Fuse 23?
hanoverfist
Car: 1997 240SX SE
Hey, all: I have a '97 240SX that shorted an O2 sensor (long story). The damage is all repaired, but the car throws around a dozen codes now, all relating to emission equipment; heated O2 sensors, FICD, vacuum purge, etc.. all the affected items are allegedly run through a single fuse (makes sense) which the Consult refers to as the fuse in position 23, but doesn't say if it's under the hood or under the dash. All my fuses in both boxes appear to be good, as do the fusible links. Anyone got any ideas?
d!ck.
Bongpain
Car: 92 240sx
well the fuse you are looking for is in here.. but what are your exact trouble codes and have you try to clear it. you can do this by going to autozone and let them clear the codes for you for FREE. then drive the car and see if the MIL come back on and if so what code come back. cheap and EZ. try it.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Did you replace the ECU? It's more than likely that there was some damage in there as well.
