tramp_drift240 wrote:that sounds good....
so its a t3 flange, is there any way i could get a 3" outlet or something? 2.25 is kinda small.
and would i just get a four bolt flange and gasket in order to fab up a downpipe for that?
They dont make that type of compressor housing for the 50 trim. You really dont need it, its going to be more lag without any benefits. For your hotpipe you dont really need a large diameter pipe, its just going to create more lag. Ideally you want the same size hotpipe as your turbo outlet.
It would be a standard Garrett 5 bolt flange for the t3/t4 to get a downpipe made. The 4 bolts are usually found on the bigger turbos.
Like i say, if you wanted a 50 trim i can get you one at a good price thats going to come with a warranty and be hand built by a pro.
Pro > Factory assembly line
GTR PrYdE wrote: Well I really meant the 3076r, but even the 3071 spools decent but cost twice the price of a 50 trim with very very similar results.
Oh, still though, any gt30r is going to spool a crap load faster than a gt35. Your absolutley right about the 50 trim pretty much having the exact same results as a GT3071r though.
