funny fuse problem 01 g20
Axel Grungy
Car: 2001 G20 5spd
This seems only to happen when its hot out (now). Ill drive somewhere and turn off the car. When i go to leave a few mins later, i turn on the car and the radio and wipers dont work. Check the fuse, its not blown (7.5 amp). Turn off the car, pull the fuse, put it back in. When i start the car it works again til i turn it off lol. Do i have some gremlins or what??
nametakennow
Car: '06 MINI Cooper S
Something is making an intermittent connection. Have you checked your other accessories when this happens to see if anything else doesn't work?
Axel Grungy
Car: 2001 G20 5spd
as far as i know everything else works. Next time it happens ill check everything.
Axel Grungy
Car: 2001 G20 5spd
noticed the power mirrors dont work when this happens.
ABNRML4U
Car: Nissan B13
That's a very clean G20 you have there are you the original owner? Dude nice ride
nametakennow
It doesn't make much sense. That said, my stock stereo wouldn't backlight most of the time. Then again, it eventually went caput completely and everything else worked fine.
Check your battery terminals and grounds for corrosion. Other than that I'm pulling a blank at the moment.
Try Nissan Online Mechanic. They're busy in there, but eventually one of the techs gets around to most things, and this is probably pretty simple for them.
