*click image for more details*
$999.95 while supplies last
+ Free Shipping w/ FRSaver if applicable!
The Type Two Coil-Over is Function & Form's flagship full bodied coil-over.
More aggressive than the Type One, they aimed to make it the ultimate
street inspired coil-over. Their philosphy was a coil-over designer for street
durability, comfort, and style, but can endure the occasional track days.
Added features:
- One year warranty.
- 32 levels of dampening adjustments.
- Dampening adjustments made with a knob that "clicks" at each level.
- Steel construction of lower mounts for maximum strength.
- Adjustable camber plates.*
- Adjustable pillow ball mounts.*
- Adjustable ride height from the bottom mount. [1]
- Special oil lubrication to withstand conditions from -40 degrees Celsius to 200 degrees Celsius. [2]
- Dual tube shock design for maximum ride comfort.
- McPherson strut piston size 50mm.
- Double wishbone piston size 43mm.
FRSport Team
AIM: FRSportsales
Email: [email protected]
