nshannon »
https://forums.nicoclub.com/nshannon-u135496.html
Sun Oct 04, 2009 5:33 pm
91 240 hatch, redtop fmic, 255lph pump, megan fpr, safc2, stock turbo and block the car dosnt run well once the boost begins to go posative(i can only go 60ish)when you remove the oil cap air pulses from the valve cover, dont think thats goodon a compresion test #1 cyl holds 120 while the others hold 150when the maf hot wire is disconected from the ecu the car insantly idels better, i have tried this with and with out safc2 connected between maf and ecu.why do i have so much presure? valve seal? causing bad performance? in order to use a diffrent maf (Z32 or Other) do i only consult the chart supplied by apexi for which hot wire to set to (hw4 or hw6)any wisdom is welcome
