Now there's a thought. Nissan didn't just put it there for looks.qship96 wrote:why not replace the missing cover,especially with all the salt used in your area-all that salty road spray will slowly destroy everything under the hood
One good reason is that it is almost $300 from Joe for the 94 and not something I have found available at any local junk yards. My was torn at the points that attach to the body and began to hang and scrape the pavement too noisy ....so I removed them........I want another one too, just have not found it.qship96 wrote:why not replace the missing cover,especially with all the salt used in your area-all that salty road spray will slowly destroy everything under the hood
I paid just over 200 a few years ago from joe when mine met its death on the Chesapeake Bay Bridge. Painful, but in my mind, an important part.CINNALOCKS wrote:One good reason is that it is almost $300 from Joe for the 94 and not something I have found available at any local junk yards. My was torn at the points that attach to the body and began to hang and scrape the pavement too noisy ....so I removed them........I want another one too, just have not found it.
Assuming you still have your old shield - you could use some oversized washers or drill out some pieces of metal to put between the bolt and shield. That should hold it in place. I have used metal flashing for this on another car...CINNALOCKS wrote:My was torn at the points that attach to the body and began to hang and scrape the pavement too noisy.
Geez, finally an owner who realizes that it is not there just for the hell of it.qship96 wrote:
Junk yard part is bound to be in poor condition,I wouldnt waste your time
Always be present during oil changes, and INSIST the entire sheild is removed, not just one side while it hangs under stress because the tech is too lazy to remove a few extra bolts-I always warn them upfront about THEIR cost to replace a sheild damaged due to this, then observe to inspect what I expect, and also use the opportunity to inspect underside front to back looking for future maintenance needs with my flashlight in hand-they get the picture that I am a meticulous owner by then and act accordingly.
It is Important without a doubt!!! I beg to differ though, that it is worth 300 or even 200 dollars for a oem piece of plastic, that is not unique.maxnix wrote:Geez, finally an owner who realizes that it is not there just for the hell of it.
I wonder how long it extends AC compressor and alternator life by just keeping road grime off it? Not to mention proper engine air flow management for better cooling. i thogut it was closer to $200 from Joe.
I bet it is well worth $300.
Easier said than done-the shield is not just a flat slab of plastic, but a molded piece that fits precisely up under there- no way any flat slab of home made material will duplicate the factory molded oneCINNALOCKS wrote:
It is not something I would do. When you can do as one member suggested and cut your own with a dremel tool and some store bought material.
When so many members are do it your selfers why pay for such so much for such an easy fabrication even for a novice like me?
Once again forum members thank you for the information that allows us all to make choices based on personal preferences and economic considerations.
I predict you will be there sooner than you think. Maybe next set of tires?Desmoquattro wrote:The cover was gone when I bought the car. Doesn't worry me much, this isn't a show car and I plan on running it into the ground, considering the price I paid for it.
1.) Try fitting it on anonther car. I assure you, it is unique to the G50. It is not flat, so fitting a piece of plastic may or may not work.CINNALOCKS wrote:1.) It is Important without a doubt!!! I beg to differ though, that it is worth 300 or even 200 dollars for a oem piece of plastic, that is not unique.
2.) Once again forum members thank you for the information that allows us all to make choices based on personal preferences and economic considerations.
Another advantage of a remotely located oil filter.superuber wrote:My cover never comes off!
I never said economic conditions were paramount.maxnix wrote:I predict you will be there sooner than you think. Maybe next set of tires?1.) Try fitting it on anonther car. I assure you, it is unique to the G50. It is not flat, so fitting a piece of plastic may or may not work.2.) If ecnomic considerations are paramount, than why would anyone own a $50+K imported luxury V8 sedan? It has to return something to the owner beyond mere bluebook value. My Q45 are more valuable to me than a $200 part.
Modified by maxnix at 8:33 AM 3/4/2008
True. But I think that deep down, everyone wants to have a perfect Q. Economics and social influences have slowed the process down for some. If I didn't have anything else to do, my Q would be in tip top all in one go, rather than doing things little by little. Sometimes I feel that by the time I get one problem fixed, it'll be time to fix another one. So on and so on. A vicious cycle.CINNALOCKS wrote:The other thing I want to bring up is that by our own admission ....only a small percentage of the vehicles on the forum are properly maintained. The reason for that is purely economics.Modified by CINNALOCKS at 2:23 PM 3/4/2008
