Tech12 »
https://forums.nicoclub.com/tech12-u11752.html
Fri Jan 14, 2005 5:42 am
Obviously, I have a problem. Here goes: I was enjoying some twisty roads on the way home from a buddy's house in my 91 s13 with newishly swapped in 93 motor. I hit the top of second, shifted into third, and the revs fell all the way to zero. "Crap" I though. "something must have come loose when I shifted... Well, anyway, I pushed the car back to my friends driveway and started poking around. The car would turn over, but give no hint to actually wanting to start. I eventually discovered I had NO fuel pressure, so naturally, I diagnosed the problem as a dead fuel pump. Now, I'm out 90 bucks, in a Walbro, and the car still hasn't run. The fues to the pump is fine. When I turn the key, I hear nothing coming from the pump, but I can get it to prime if I put a jumper wire between the contacts under the fuel pump relay. Now then, the reason I don't know if it's the realay or now is because I have tried to stick various other green relays from other relay boxes into the egi pump relay, and still get nothing.
I know this is a long post, but I have searched and found very little, and I hoping that throwing all of this detail at you guys can help. Thanks in Advance-Lech
PS: For anyone searching about this kinda thing, here is a fun fact that took me a while to decode: EGI PUMP means FUEL PUMP so when you're looking for your "fuel pump relay" maybe this post will help you out.
