Turbo magazine is retarded. Technically you shouldn't be using a girdle for NVH. Individual main caps should be used on a fully counter weighted crank. It's going to be harder to make power with the girdle. Main bearing caps should be used from the KA24DE truck engines.B-Metts wrote:that and with a fully weighted crank you're going to have to take a few pieces out of the block
got this from turbo's magazine on their buildup of a 750+ ka-t.
it's a DE motor, but you still get the idea.
why wouldn't a girdle be better then just caps. the girdle adds to the structure of the block with or without a fully counterweighted crank. im all for a fully counterweighted crank and with that why would anyone need to swap in an sr.Bigvinnie wrote:Turbo magazine is retarded. Technically you shouldn't be using a girdle for NVH. Individual main caps should be used on a fully counter weighted crank. It's going to be harder to make power with the girdle. Main bearing caps should be used from the KA24DE truck engines.B-Metts wrote:that and with a fully weighted crank you're going to have to take a few pieces out of the block
