baggedb22 »
https://forums.nicoclub.com/baggedb22-u90427.html
Mon Mar 22, 2010 1:56 pm
Ok guys its kinda hard to pin point b/c i did everything at once, and this is getting pretty annoying but i will not let it get the best of me, ok details are Fully built sr with cp pistons, eagle rods, acl bearings, tomei 270 cams, bc springs and retainers, jim wolf bronze valve guides, full-race t4 dual gate manifold with gt35r, and aem ems to keep everything under control, i just broke 2,000 miles on this set-up and its been smoking from the first start, and its an oil smoke, I need some extra ideas/ advice..
Heres everything i have check/changed so far
compression and leakdown tested 2 times so far both look greatThere is a small amount of oil in my catch can but pretty normalno oil in antifreeze or antifreeze in the oilthere is pressure when the oil cap is removed, not sure if this is normal with the big cams first i thought it was blowby BUT THERE IS VERY MINIMAL NORMAL PRESSURE AT MY DIPSTICK TUBE, AND IN MY CATCH CAN LINE FROM THE BLOCK AND NORMAL PRESSURE AT THE VALVE COVER Tbrand new pcv valveChanged oil drains around thinkin maybe that was the problemsent the turbo back to Garrett and they said there was nothing wrongthere is no oil or residue in my intercooler, intake manifold, air filter, on plugs, or any notice able oil in the exhaust manifold, turbo or downpipe i believe its burning it all off
The only thing i can think of right now is the valve guides, the intake side were intolerance but the exhaust side were not so we replaced just the exhaust side, im thinking when they did this they just pressed them in instead of heating the head and freezing the guides, and its leaking just enough to see it at an idle, The car also made pretty good power thats another reason why i dont think its blowby the car made 440rwhp on the break in tune and 18psi..
Any info would be awesome, im in need of some much needed help, the race seasons about to start!!!!
Also heres a pic of my bay just incase anyone ask's
