crashcourse wrote: I did a swap for a guy the beginning of last summer with an s14 . The same thing happened to him except his #4 cylinder slapped the head the bearing was gone..
His head looked real similar to mine did but I really wanted to rule that out . You know if you have ever torn into these motors the oil pump is first on last off .
I've never seen nor heard of a failed bearing causing the piston to make contact with the valves. Only a failed rod/rod bolt, mistimed motor, stuck valve, or really bad valve float should cause that to happen.
Either or, you haven't seen metal shavings in your oil yet, so you can put spun bearing down on your list of possible problems, but that pump sounds awefuly suspicious from what I'm reading. To really put a possible pump in persepective, pull your cams. If there's little oil in the rear of the head, then the cams should have chewed up the journals a bit.
