slipnfall wrote:Just to be sure/curious - in that pic where was your distributor rotor pointed?
If/when you do take it to your mechanic, have him remove/discard the two upper timing guides in the below diagram: they will only cause trouble down the road.
Timing a KA is really not that hard - I realize that the mechanic may not have done it right (and so he/she should fix it), but if transporting the car is a hassle there's plenty of info/help here to do it yourself (see the below link).
In this case I think you may want to bring it to the shop anyway, on the *off* chance this caused a bent valve.
Good luck and keep us posted.
well i'm going to call briancrower since they are stage 2 bc camshafts. i dont know much about aftermarket cam lobes, how they are suppose to face or if they are suppose to face outward no matter what.. actually the ecu havent been tested to work w/ the new tune from enthalpy but seems like power, sterio, lightings and everything seem to work fine. thanks for all the help, I highly doubt its ecu though.
and its a bitTTCh when polishing the intake manifold unless if you have all the right tools, i used a dremel and lots of sand paper. make sure to finish it off w/ 2000grit and then MOTHERS metal polish for that nice shine. its not all hard to maintain, the reason why it looks dull is from all the grease when dropping the motor. it's worth all the time and blister. i'll post up more pictures when i clean up the engne bay.
EDIT: i called up Briancrower and the cams where made for Front wheel, so i have to switch the cams around for it to be rear wheel. so i already talked to my mechanic and he will fix it for free. i hope this is it,
Modified by 240sxvaj at 11:28 AM 12/29/2008
