Not true. Rotors are hubcentric, not lugcentric. You can drill the holes with nothing more than a handdrill and a clamp.skydragoness wrote:Just keep in mind that if you do insist on staying 4 lug you are going to have to find a machine shop (or yourself--if you have the proper equipment and know-how) to drill the extra holes in each rotor whenever you need to replace them.
I doubt it. It's gotta be more than that.stacy wrote:is it true that the rear z32 calipers only make a 2% differnerce in stopping power from the oem 240sx rear calipers?
Braking torque is a function of pressure (line pressure / area of piston), friction coefficient (brake pad material related), and rotor diameter.stacy wrote:is it true that the rear z32 calipers only make a 2% differnerce in stopping power from the oem 240sx rear calipers?
I'm aware of the former, but as for the latter, I was told you couldn't drill rotors w/ anything less than a drill press or you'll stress the rotor hat. (ho ho ho)naed240sx wrote:
Why would using a hand drill stress the hat if a drill press does not? That makes no sense. Tons of people use just a hand drill. It's fine.skydragoness wrote:
