Yeah sorry I missed that.chrismo240sx wrote:i changed the fuel filter during the tune-up ....guess u missed that?
go get a couple of cans of brake cleaner... turn the car on and let it idle.. then start spraying the lines with the clean.. if the idle chances then there is you leak.chrismo240sx wrote:um idk about the vacc leaks...maybe
damn the ka has a ton of vac lines, so whats the easiest/fastest way to check for a leak?
if there is a vac leak somewhere you should NOT hear a swoosh sound when you open the gas cap if you do then it should be okchrismo240sx wrote:um idk about the vacc leaks...maybe
thats interesting, because sometimes i hear a swoosh and other times i dont. hmmIDRFT95S14 wrote:if there is a vac leak somewhere you should NOT hear a swoosh sound when you open the gas cap if you do then it should be ok
I now know what forum not to come into for car related advice.xX RB Xx wrote:
well that is what we did we were looking for a vaccum leak on my single cam.. and fyi it worked,Papi Chulo wrote:
Intake vacuum and the "vacuum" created by the fuel pump/expanding gas fumes are not related.
Lol. You can open a gas can that has been sitting in the sun and it will "swoosh".
