full throtle problem
alysesparents
Car: 91 240
whell i posted on here a fiew days ago that i cleaned my rb20 while in the car then it started to run really bad found out that the #5 sparkpug was under water drained the water ran better except that under full boost and full throttle it sputters
so i thought that i might have fouled the plug replaced the plugs still sputters
so i thought i fouled the ignition coil replaced it with one from a q45 still sputters
then i cleaned all of the electrical connections with electrical parts cleaner it helped for mabey 2 hours I am really confused and starting to get frustrated please help thanks
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Did you check your injector clips? Check the ecu for codes.
alysesparents
Car: 91 240
i checked the injector clips they were dry but i didnt check the computer for codes is it the same to read as the ka24de computher
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
yes.
why didn't you just continue your previous thread?
alysesparents
Car: 91 240
I couldnt find it I searched back like 4 or 5 pages
POOPmouth
Car: The Devils pimp ride
did u fix problem yet-?
alysesparents
Car: 91 240
no not yet it is getting frustrating
PYRONIX
Car: R32GTR & Rb20det S13
check your airflow sensor
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
alysesparents wrote:I couldnt find it I searched back like 4 or 5 pages
An easy way to find your old threads is to click on your screen name in a current thread. It will come up to your profile. On the right, there are two options.
View <username>'s watched topics
and
See threads started by <username>
Then just search all the threads you started till you find the one you need.
Hope that helps for next time.
-Neal
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
might also wanna try to reset your tps.
alysesparents
Car: 91 240
ok fixed it for shure this time it was my spark plugs they were gapped at .39 and they are supposed to be at .30 it is running fine for a full 24 hrs now thank you once again for your help
