Full suspension upgrade
driftfan420
I've been doing a little searching and was wondering that's the best suspension package to go with in terms of all around car handling, rigidity, and craftmanship for a 93 240sx. I've gotten coilovers, I just need to get Frount/rear LCA, Camber arms, tie rods, toe rods, tie rod end links, tension rods, rear traction rods. I've been looking at Ikeya formula, and they are a bit spendy. I'm looking for something that's quite beefy and solid. I know alot of places have package deals for all the rear suspension. (like peak performance, enjuku, SPL parts) Suspension is out of my league so i need a little assistance. Thanks, Your help is much appreciated.
Modified by driftfan420 at 7:18 PM 4/8/2008
TougeChallenger
Car: 91 240SX
For upgrading your LCA I was going to say SPL. But you will have to shall out some money becuase SPL and Ikeya are pretty much the only company ive seen who makes LCA. And you really dont need to upgrade your LCA,ecspecially in the front. your camber plates should give you enough ajustment. Upgrade your RUCA and you pretty good to go. For drift set up, you should upgrade coil overs,RUCA,sway bars,rear toe rods,traction rods,tension and tie rods. Circuit sports makes some great arms and there affordable as well. most of the companies that make suspension parts are all very similer.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
You really should check the craftmanship of the welds! CS makes good turbo lines but if you look at the welds on the CS RUCA's you can tell the craftmanship of the welds suck! I just got megan RUCA's lasterday! Dident even put em on yet. I seen the best welds on the megans for the price. Kazama's and SPL look but not for the price!
