Full set of 205/70/15 Toyos on my hatch.
boxcarbill
Car: '07 Versa SL hatch 6 speed white/beige int.
Put a full set of Toyo Eclipse (Les Schwab's house brand from Toyo) 205/70/15s on my hatch (stock alum wheels) yesterday. I put the car through a thorough test which included turning the steering wheel fully both left & right. I heard no rubs.
I inspected the wheel wells and saw 3 very small scuff marks where the tires managed to contact the plastic. These marks were well away from the edges of the plastic wheel well liner and easily flexed in 3/8 inch when I pushed lightly with my finger. They fit!
p. s. I did notice there is some difference, especially in tread width, between different tire brands. The Toyo Eclipse was on the narrower end of the range.I didn't notice any difference from a stop in first gear, and I'm getting an additional 8% overdrive.
bikeman
Car: 2007 Nissan Versa SL
Which tires do you plan to use this winter?
David
boxcarbill
bikeman wrote:Which tires do you plan to use this winter?
David
don't plan to do any snow tires at this point in time. I can hole up in the house for weeks if needs be.
KimberKenobi
Car: the Camel
good plan? bad plan? hmmmmm.... ;oD
Did you keep your original wheels?
Bubs daddy
ABS, CVT
Quote »don't plan to do any snow tires at this point in time.[/quote]What is this snow you speak of?
Clipsed
Car: 07 ALL BLACK Nissan C11ST, 01 Mustang GT Vert, and 94 Suzuki Sidekick JX 4x4.
LMFAO!! HAHAHA
boxcarbill
yes, they are on the car.
KimberKenobi
Car: the Camel
I missed the bit where you just got new tires and not new wheels+tires...
I'm special.
