Kalypso »
https://forums.nicoclub.com/kalypso-u71724.html
Thu Aug 14, 2008 11:04 am
ok, thats established
the only remaining challenge are the welds in tight spots, I dont know how to weld but I will learn just so I can make a manifold.
when asked what type of piping and material I should use.
b-rett from nico responded" i would use either 1.5" schedule 10 or 40 304SS. if you figure out how much you need, we can certainly supply it. if you'd rather go elsewhere, and i understand, try ace stainless...they are competitive. if you go sch. 10, brace the turbo somehow using heim joints, etc. i can help you out with that if need be. i did it on my 1jz manifold. keep it clean clean clean and bevel your buttwelds to get max penetration. best of luck, "
