Full exhaust Question.
w00t_Masta
What makes a full exhaust? Is it testpipe/downpipe/muffler?
Or what combo, and where does the Cat-back fit in?
If i bought the apexi n1 dualls off http://www.heavythrottle.com would that just be the muffler or what? :confused:
SWIFT_DRIFT
First you have your exhaust manifold that is bolted to the engine. After that is the downpipe, then cat (or test pipe if you replace the cat with a straight pipe), then after the cat is the rest of the exhaust piping to the muffler. It is called "cat back" because most exhaust systems only replace the piping from the cataylitic converter to the back of the car, hence cat back.
to simplify heres what you would need for a "full" exhaust system:
downpipe, test pipe (or whatever you wanna put where the cat goes), then cat back exhaust system.
SpeedRacer1
Car: 1990 240SX, G35
This is what the N1 duals come with. It is a full cat back system.
SpeedRacer1
And this plus two gaskets and about 10 screws.
w00t_Masta
Thanks a lot guys, really appreciate it, and speedracer i envy u.
But to make sure, if you just put a test pipe in that means there is no cat. correct? So when emissions time u replace it w/ a cat i would assume?
SpeedRacer1
There are generally three types of pieces for this middle part of the exhaust system. The first is the actual catalytic converter, the second is a dummy cat which has been debated as to whether it is as good as the third option, the test or straight pipe.
If you intend to pass emissions have a cat on the car, the lack of a cat wont provide a HUGE increase in power but every little bit helps I guess.
I had a dummy cat (which if anyone wants ill sell) and now im using a random technologies hi flow cat. I use it more for the fact that its cheap alternative cat since the stock new Nissan cat is expensive.
Blade7764
Car: 1990 240sx Fastback. Intake and straight pipe.
Does anyone know if any company makes a replacenment pipe for the cat. for the 240sx.
SpeedRacer1
If your talking about a test pipe then a few companies make them, the easiest thing to do would be to go to a muffler shop and have them make you one. It should be less than $50. If your talking about a replacement Hi flow cat then you can get a random technologies one, there are a couple other companies out there but the names escape me at the moment.
Oh yeah HKS makes one for $800.
Blade7764
Cool, thanks:ylsuper
redrocket
Car: 1987 Nissan 200SX SE
2007 Chevy Silverado Classic Crew Cab
1999 Kawasaki ZX9R
be fore warned that cutting that cat makes the 240 sound close to a honda had mine cutoff it is loud and sounds like a honda but with the bigger engine it is deeper sounding so if you don't want the honda sound I do not recomend cutting the cat
SpeedRacer1
This is what a test pipe looks like under the car and around how much it costs. http://cgi.ebay.com/ebaymotors...83807
NISMOracing
Car: Auto Racing/Modifying, Snowboarding, Gaming
say...what does the catalytic converter do anyway?
redrocket
1999 Kawasaki ZX9R
basicly it burns what gas is not burned in the cylinder that has been sent to the exhasut if i am wrong please correct me
SpeedRacer1
Heres how Catalytic converters work:http://www.howstuffworks.com/c...r.htm
And more importantly how the amish work:http://www.howstuffworks.com/amish.htm:fruit
Blade7764
hahah, i just read that like a week ago, i also read how engines work. pretty basic but helps if you have no idea
Silvia007
Car: 93 Nissan 240SX SE Fastback
Hey guys... does the Dual N1's run along the same path as the stock exhuast... reason is I don't want it to look crooked like some honda guys where the exhuast piping seems to almost touch the ground as it has to go under the gas tank. Thanks.
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
Silvia007 wrote:Hey guys... does the Dual N1's run along the same path as the stock exhuast... reason is I don't want it to look crooked like some honda guys where the exhuast piping seems to almost touch the ground as it has to go under the gas tank. Thanks.
It runs much straighter than the stock pipes. At the differential it drops slightly lower than stock (only because the pipe is larger in diameter), but there is a gentle bend back up and towards the drive side. It exits facing up and out... so it is nowhere near the ground.
