OK, so the last upgrades i did were a 3inch dp and 3inch piping with a less restrictive exhaust.
when i wot, and hit full boost, the car seems to cut off and the afrs are rich?
anything before 7psi, car runs good and pulls but when i hit 7psi, you can hear popping noise from the exhaust and car seems to hesitate when i hit full boost. ever since hearing the noise i dont hit 7psi.
i was reading a thread that had similar problems but it was for a ca18det.
could it be my spark? i have a walbro and adjustable fpr.
my spark plugs are the ngk bkr7e.
could it also be the tune? what i dont get is that under boost (below 7psi), afrs are fine but once i step on the pedal real quick and hit full boost the popping and hesitation occurs.
i dont hear anything in the motor under boost (pinging or detonation) mostly from the exhaust and its only that popping noise while under acceleration.
any help is appreciated! thanks!
ill try to get a vid of the sound
