Full bolt-ons
capblueberry
Car: 1995 Nissan 240sx
i was just curious about the average HP gain if i put all bolt ons on my car?
including:megan 3 in cat backprobably obx headersaem short ram intake
also anything im missing please inform me. thanks!
simmode1
Car: Red '95 S14
I think ImportTuner and Modified Mag did similar mods and added a high flow cat for 20+ rwhp. Cam swap might get you another 10hp w/ a better powerband too maybe.
Of course all this assumes your KAde is in good condition and not beat to hell...
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
simmode1 wrote:I think ImportTuner and Modified Mag did similar mods and added a high flow cat for 20+ rwhp. Cam swap might get you another 10hp w/ a better powerband too maybe.
word. really hard to get much more than 35hp without some tuning and/or forced induction.
capblueberry
yea i have a 95 240, the body has over 200k miles and the engine has roughly 10k miles as it was rebuilt. still in good shape.
srpowered240sx
motors in good shape then. you pretty much have your answer. step it up and get a turbo.
sr20power
Car: S14 Zenki
srpowered240sx wrote:motors in good shape then. you pretty much have your answer. step it up and get a turbo.
Well if you can't go that route, then there is always the weight to power ratio. If you don't mind a gutted car, remove some weight from the car. Won't cost you anything....
Black on Gold
rebuilt motor just SCREAMS turbo
davidb688
i don't even know why this is still an option.
locoluna825
Car: 90 240sx coupe
get a light weight flywheel on that puppy
i240sx
Car: 240sx coupe
i/h/e/light fly/light drivetrain/ electric fan/light weight pulley/ weight reduction=a/c, tard, carpet, light seat, back seat, carbon fiber trunk and hood/jwt cams/jwt ecu/tuned/= will get you close to 180-190whp on a healthy ka... total spend= enough to go boost for 220+whp
simmode1
Car: Red '95 S14
davidb688 wrote:i don't even know why this is still an option.
Zombie thread...
Kento
Car: 95 s14 5spd.
the ka24de does not responde as well to bolt ons as much as other cars. Just save up 700-800 bucks. buy a t25 from an sr20 with oil and water lines.. All the componets to make it run, Tmanifold,ECU,Injectors. You can find all that stuff used and in great running condition, the t25 setup should put you anywehre from 180-200hp depending on ur engine, psi on these turbos are max 7-8psi ive seen 9psi. with 200 hp ur 2,000 and some odd pound 240sx is gunna fly anywhich way you go, sideways or foward. It'll be a fun car that'll go quick.
-Kento
s14derrick
Car: 1995 nissan 240sx
i240sx wrote:i/h/e/light fly/light drivetrain/ electric fan/light weight pulley/ weight reduction=a/c, tard, carpet, light seat, back seat, carbon fiber trunk and hood/jwt cams/jwt ecu/tuned/= will get you close to 180-190whp on a healthy ka... total spend= enough to go boost for 220+whp
the thing i like about building na first is. once you go turbo you are already set for higher numbers then on boost alone . most of those parts besides the intake and header will still be on when you go boost
finalgear
Car: 91 240sx /90 240sx
Kento wrote:the ka24de does not responde as well to bolt ons as much as other cars. Just save up 700-800 bucks. buy a t25 from an sr20 with oil and water lines.. All the componets to make it run, Tmanifold,ECU,Injectors. You can find all that stuff used and in great running condition, the t25 setup should put you anywehre from 180-200hp depending on ur engine, psi on these turbos are max 7-8psi ive seen 9psi. with 200 hp ur 2,000 and some odd pound 240sx is gunna fly anywhich way you go, sideways or foward. It'll be a fun car that'll go quick.
-Kento
Max psi on a t25 is 13psi and he will be making over 200hp on a boost ready KA at 12psi
Gabes13
Car: rb20det s13
t25 is too small for a ka
capblueberry
clicked on this thread to see what it was all about to realize that its actually one of my threads from about a year and half ago haha
s14derrick
did you go full bolt ons or turbo? lol
s14derrick
Modified by s14derrick at 3:33 PM 7/21/2009
