Fujita Intake installed
All things Altima Coupe.
imdavit
Car: 08' Radiant Silver Altima Coupe 2.5s
i just installed my fujita intake today and i have this vibration problem, not sure if its even a problem but does anyone else feels the same vibration? and this is the also the first thing i actually installed onto my car by myself, so i hope i didn't f anything up
also i used my oem clamps because the fujita clamps were so annoying to screw in, it had some type of rubber in the screw i dont know why so i gave up on using those clamps. could this be why?
i drove it around for like 45 min on the highway and all and i feel that vibration when i gas. and shiet its pretty loud, but im hoping thats the right kind of noise coming from my intake.
this was my first diy on my car so any tips would be great!
thanks
ItsEcko06
you know i actually bought the same intake weeks ago and installed it and noticed the same problem.
it seemed like when i accelerated from a stop it made this weird vibration i felt in the gas pedal but it only did it for a brief second like 2 or 3 quick vibrations but went away. i don't have my car at the moment but i know what u mean.
its strange, i followed all the instructions in the box and used all parts it told me too.
imdavit
exactly what i was talking about. . .
go us!
ItsEcko06
haha, unfortunately i don't have a solution. i'll check when i get my poor car back. hopefully with its new stillen front fascia! ill keep u posted abt this "problem"
DEFTON35
Car: 2008 Altima Coupe 2.5 MT - White
i just installed mine the other night but had a different problem. where it told me to secure the vibration mount to the ca,r there was alrady something using that mount, some type of coil thing. but in the directions the coil thing is not pictured. so i had to secure it with a different type of washer. has this happend to anyone else anyone else
D-Roll
Car: 08 Nissan 350Z Touring Coupe
I never had an issue with mine, and it's been installed for over 6 months now.
toxik
Car: 09 Pearl White 370z
I had the same problem with my intake after the installation. I inspected it and saw that it was touching the fuse box I believe, so make sure its not rubbing against anything.
I simply turned it to make sure its sitting on its own, and now no vibration.
ESP
Car: 2008 SexyBlack A/C
I have never felt that vibration you guys are talking about, but I've heard of it from other people. It's not limited to just the Fujita intake. Did you guys remember to disconnect your battery beforehand?
DEFTON35 wrote:i just installed mine the other night but had a different problem. where it told me to secure the vibration mount to the ca,r there was alrady something using that mount, some type of coil thing. but in the directions the coil thing is not pictured. so i had to secure it with a different type of washer. has this happend to anyone else anyone else
Now this is something I can help you with! Fujita changed the design of their mounting bracket for the 2.5 a few months ago...but never bothered to change their instructions! I just took the top-most screw out of the bracket that holds the fusebox in place and screwed the rubber bumper into there. It's the perfect location for it (I'm pretty sure that's where Fujita intended for us to place it) and nothing is even remotely loose or rubbing on anything.
imdavit
no i didnt d/c the battery beforehand =[ is that a big deal?
o man
ESP
Well, in theory disconnecting the battery resets the ECU (which is something you're traditionally supposed to do when modding anything that affects a/f ratio). However, with ECUs being as sophisticated as they are nowadays, I'm not so sure that it's as important. I still do it just as a matter of habit and I haven't had any problems so far!
Try disconnecting your battery (just the neg terminal), let it sit for about a minute, reconnect it and turn the car on. Let it idle for about a minute or so then take it for a spin.Might work...might not. It's not gonna hurt to try though!
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
Disconnection of our batteries does not reset the ECU, its flash based, it'll f up your radio though!
imdavit
figured it out, it was because the pipe was hitting the brake fluid container.
thanks all!
ItsEcko06
i might wanna look into that when i get my coupe back. thanks!
HuyyNguyen
Car: Nissan Altima Coupe 2.5s
blah aifoiajfea
SamC.altimacoupeneedshelp
Car: 2008 Nissan altima coupe 2.5s w/ moonroof, convieince package...i need websites that have the things
D-roll [QUOTE=D-Roll]I never had an issue with mine, and it's been installed for over 6 months now.[/QUOTE, how much faster does your coupe feel after all ur mods, i have the 2.5s 6m, and its slow as hell, would you consider it alot faster than it was before??
Tommy:]
Car: Altima Coupe 2.5s MT
ESP wrote:Now this is something I can help you with! Fujita changed the design of their mounting bracket for the 2.5 a few months ago...but never bothered to change their instructions! I just took the top-most screw out of the bracket that holds the fusebox in place and screwed the rubber bumper into there. It's the perfect location for it (I'm pretty sure that's where Fujita intended for us to place it) and nothing is even remotely loose or rubbing on anything.
Sorry to post again but nobody answered my other thread in the exhaust section. ESP, how did you go about removing the top fuse box screw? Did you have to go up and under the wheel well?
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
LinkNuc wrote:Disconnection of our batteries does not reset the ECU, its flash based, it'll f up your radio though!
Thats absolutely false. The ECU in this car is a learning based computer program. As you drive the ECU records and adjusts things idle air intake, a/f mixture ratios, and throttle position. Taking the negative off the car reset all this to relearn with the larger intake and volume of air being applied.
imdavit
does this apply to everything? cuz i jsut got my nismo exhaust installed like a week ago. should i reset everything and let it adjust again? Or is this totally unnecessary? lemme know thanks!
bunda4th
Car: 2008 Nissan Altima Coupe 2.5S 6MT
You do not need to reset it if you just change the exhaust since the only difference is you are letting more air flow out faster. The calculation of a/f mixture is already done and recorded.
The only time you would reset it is when you do actual engine work suck as fuel injectors, intake, headers/manifold, etc...
ESP
adidas2go wrote:Thats absolutely false. The ECU in this car is a learning based computer program. As you drive the ECU records and adjusts things idle air intake, a/f mixture ratios, and throttle position. Taking the negative off the car reset all this to relearn with the larger intake and volume of air being applied.
Thanks, Blake! I knew I was right...
Tommy: wrote:]Sorry to post again but nobody answered my other thread in the exhaust section. ESP, how did you go about removing the top fuse box screw? Did you have to go up and under the wheel well?
You open the hood and take the bolt out with your socket wrench. Seriously...it's the uppermost screw holding in the fuse box to the strut tower. Just take a look at where the mounting bracket on your intake is and find the closest place to screw that puppy in.
Tommy:]
I did that but the nut comes out and the screw itself still sits there. That was the first thing i tried before i went and posted on here haha. So its basically a riveted stick holding the fusebox in without the nut at the end. It wouldn't come out.
ESP
You're talking about this one? not image of my own engine bay
Tommy:]
Yes that exact bolt. The intake will fit perfectly on the bolt but when i removed the nut the riveted part was still in there, i couldn't pull it out. Its as if the screw was on the other side under the wheel well or something. I don't know how to take it out.
ESP
Waaaaaaait a sec.......I'm beginning to remember something like that...
Keep in mind that it's been quite a few months since I did it myself, and I've been sick for the last week so my thoughts are naturally a bit muddled anyway.
IIRC, leave the bolt that's in there and just screw/twist the rubber bumper onto it....or something like that. It's really dark out right now, I'm exhausted, I've been drinking, and I can't find any batteries for my flashlight so at the moment I can't take a look to see how I did it. I've got a shoot tomorrow morning, but after that I'll have a look-see and give you a better idea of how it's done. Sorry I can't be of more help at the moment!
Tommy:]
Haha you've helped me plenty already, I went outside about an hour ago to double check. It's really cold to try anything right now anyways. Thanks for the help so far!
LinkNuc
Wrong, send Nissan an email if you don't believe me.
"Dear Mr. Link,
Unplugging your battery will result in a reset of the factory radio settings only. Your Electronic Control Unit or ECU will retain your diving habits to maximize your performance and assist in fuel economy. If you are experiencing any issues with a Check Engine Light or CEL please take your car to a local dealership. According to your address, West Hills Nissan on University Blvd. in Moon Township, PA would be the closest to you. I am glad you are pleased with your Altima Coupe. Do not hesitate to contact us again with any questions you might have with your Nissan.
Nissan Consumer AffairsP.O. Box 685003Franklin TN 37068-5003(800) NISSAN-1 (or 800-647-7261)8:00 a.m. - 5:00 p.m.,
Tommy:]
Bump for ESP
