Fujita intake installed now brake pedal vibrates
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
2dr_sentra
Car: 1997 200SX SE-R, 2007 Versa SL 6spd
So yesterday i get my fujita cai, installed it in less than an hour. I noticed the brake pedal vibrates now.
I also noticed the 45* coupler that connects to the throttle body rubs the brake fluid reservoir, I trimmed it back some so it didnt rub, which eliminated most of the vibration.
Has anyone else had this issue?
clearances are super close.
Modified by 2dr_sentra at 11:12 AM 5/3/2009
the djay
Car: 2008 Versa SL HB w/ full tech option
2006 Jeep Grand Cherokee Laredo
1976 Chevy Malibu
Hmmm, I'd be a bit careful with that. After awhile wouldn't it compromise the brake reservoir and maybe cause it to crack due to pressure and vibrations?
CodeRed
Car: 2008 Nissan Versa S MT
I don't know how the Fujita bolts up but you should be able to loosen the bolt and push it back towards the firewall more.
2dr_sentra
CodeRed wrote:I don't know how the Fujita bolts up but you should be able to loosen the bolt and push it back towards the firewall more.
what bolt?
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
i guess you just have to get used to it... well i have more vibration now then i did when i installed the CAI, cuz of the header and exhaust....how do you like it in combo with the stillen?
2dr_sentra
superskunk wrote:i guess you just have to get used to it... well i have more vibration now then i did when i installed the CAI, cuz of the header and exhaust....how do you like it in combo with the stillen?
Well im just worried about it breaking the brake fluid reservoir. It sounds really good. Im happy with the performance of the intake.
im gunna call you when i get those strut bars btw.
CodeRed
There is a bolt that is by the Strut tower... as I said I don't know the Fujita bolts up...
superskunk
the fujita doesnt have that bolt....
2dr_sentra
almost wishing i bought the aem, but i cant see spending over $200 on a intake (i paid 120 shipped for this one)
I will figure something out, even if i have to have a bracket welded on.
feloniousmonk
2dr_sentra wrote:almost wishing i bought the aem, but i cant see spending over $200 on a intake (i paid 120 shipped for this one)
Can't you loosen up the clamps at both ends of that silicone coupler/elbow and rotate it to gain some clearance then retighten? You may even need to do the same for the rest of the system to buy yourself some wiggle room. If none of that works, I guess if you have a strut bar you could maybe wrap a long zip tie around the strut bar and the intake to lift it away from the reservoir.
No bolt or bracket huh? So the whole thing isn't sported in anyway? just hangs from the throttle body? That's probably your problem right there; the weight of the intake kit pulling down and putting pressure on the reservoir.
Hot engine bay + plastic brake reservoir + constant pressure on the reservoir... not a pretty picture.
Modified by feloniousmonk at 9:04 PM 5/5/2009
2dr_sentra
I fixed it, i loosened the 2nd hose and extended the intake back towards the firewall.
Return to “Versa Technical Discussions”
