Fujita intake filter specs?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Skim302
Car: Nissan Versa S
Does anyone know what the fujita intake filter's specs are? I'm going to buy a new filter and I have no idea what they are. Also, are there any suggestions on replacement filters? I have heard mixed reviews about k&n and that's what I think I'm going to go with.
NODES
Car: 2007 Nissan Versa SL (Blue)
what specs are you looking for about the Fujita?
Skim302
Car: Nissan Versa S
What size the intake filter is.
didier
Car: Nissan Tiida ST-L 2006(Japan)
MR18DE
K&N - http://www.knfilters.com/searc...-2375
Fujita CAI - CA-2821 * 6061 T6 ALUMINUM ALLOY CONSTRUCTION * CARBON PLATED T-BOLT CLAMPS * CNC MACHINED SENSOR FITTINGS * SILICONE HOSE * TIG WELDED BRACKETS * SUPER FLOW HIGH PERFORMANCE AIR FILTER * AIR FILTER IS WASHABLE & REUSABLE
The filters dimensions are 4.625” top, 6.00” base, and 6.75” in length
sinha0713
Hey so im new to this whole modding aspect and I've been trying to get as much info on intakes. One problem I did see is this weather proofing. No one seems to mention it so Im not sure if any of you more experienced guys know if thats all bull s*** or not. A friend of mine has a scion tc and started off with a CAI and changed over to a short ram because he was scared of this very problem. Also has anyone installed a short ram on their V? What advantages did you have?
NODES
the short intake is more for cosmetics on the versa, not much if any performance increase due to sucking up warm air from engine bay into the engine.
If you are worried about sucking up rain, there is way to prevent that from happening.
alex5002
Car: 2009 VERSA HATCH 6-SPEED
and how do you do that i just installed mine
br4dysays
Car: 06 Nissan Altima SE-R
you'd have to go through some pretty deep water to jeopardize the CAI on the V. I wouldn't be concerned, maybe if its lowered a little more but even then just avoid deep puddles that would submerge your bumper lol
NODES
alex5002 wrote:and how do you do that i just installed mine
this is what you need:
http://www.iapdirect.com/produ...&js=n
You can get then cheaper then that, mine came with my Fujita Intake.
sinha0713
@ nodes
thanks for clearing that up. did you get your fujita CAI at versaspeed? also a general question...the instructions that come with...are they clear to understand? Just dont want to abandon my car in the middle of the project to figure out something not written in. so any tips? thanks
NODES
Simple and straightforward. I bought mine used so no instructions. It was easy as long as you use common sense and do not cut corners/shortcuts.
Taking the Stock setup took a bit of effort though. Best advice I can give you is be careful with the MAF sensor and its wiring, fragile and expensive to replace.
medicjofiss
Car: 2009 Versa
General rule of thumb for Cold Air Intakes:
If a puddle is big enough to forcefully slow down your car (you know what I'm talking about) you run the risk of hydrolocking your engine (for the n00b's it means you have to rebuild your engine). Don't worry about rain or small puddles.
To prevent this:
A. Dodge deep puddles.B. If you drive through the deep puddle, put your car in neutral so you don't suck air up your intake.C. Buy a special adapter to divert water. I forget the name, but you'll lose some HP.
Bonus: You're not going to see huge HP gains when modding the Versa. I'm sorry, but you're not going to be able to feel much of a difference with ~5HP. Unless you just want a better sounding engine, I vote for modding the suspension or sound.
My 0.02USD. You're results may vary. Consult your physician before starting any workout program. Avoid contact with eyes.
Return to “Versa Technical Discussions”
