Fujita Intake 06 M35X
TroyDeezy
Car: 2006 M35X
Installed the Fujita intake about 2 weeks ago and lastnight the Service Engine Soon light came on. Any idea why? How to fix this? I followed the instruction, and disconected the battery during install. The OEM MAF is insatalled as well.
zerg711
I have fujita intake installed and I haven't had any problems with it. You should double check all the connections, especially the hose towards the throttle body.
TroyDeezy
Car: 2006 M35X
Code P0171 came up, and P0171 Pending. The light went away for a good two days and came back yesterday. Anyone with the same codes after installing intake? What did you do to fix this? I have only had the intake in for maybe 300 miles.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
how many miles on your car? have you searched what P0710 mean? i don't think it's MAF related but more with O2 sensors.
TroyDeezy
Car: 2006 M35X
I have 66,000 miles on the car. Code P0171 means the system is to lean in bank 1. I researched the code and it can be several things. I was wondering if anyone had the same expirence after installing an intake.
JDMlove
Car: 2006 M35X
2007 HR 350Z
TroyDeezy wrote:I have 66,000 miles on the car. Code P0171 means the system is to lean in bank 1. I researched the code and it can be several things. I was wondering if anyone had the same expirence after installing an intake.
i think you had an air leak in the intake! check the intake again.
TroyDeezy
Car: 2006 M35X
How do I check the intake for a leak?
JDMlove
Car: 2006 M35X
2007 HR 350Z
reassemble it again!! or let someone accelerate while u opening your hood. and check for any weird sounds!
