BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Sun Aug 22, 2010 11:57 pm
Welcome, you will like this car. I have had my 97' for 10 years and counting. So it holds about 6 quarts of oil, mine usually takes a good 6 when the oil filter is changed and the mechanic gives it time to drain. As for the motor mounts, surpirsed you need them but get OEM. Infiniti of Scotsdale (aka IOS, so a search) have good deals and worth mail ordering them. Plus, order from Scotsdale also, NGK OEM ONLY, no Bosch or anything else....they create more damage then good.
Now, as for you mileage, I would plan to flush EVERYTHING and replace all fluids with synthetic, transmission specially, but also consider brake fluid, diff and power steering. You can get the gear oil weight at any shop that sells good quality stuff. Mobile One at the least, Redline or Amsoil if you can find it. Those I believe are the best, but Mobile syn will do. Also, if the tie rod ends have not been done (check receipts) those are toast and you might want to order them too.
Good luck feel free to ping us with more questions.
