Hey all,
I've been lurking for a long while, soaking information like a sponge. However I'm now in need of some assistance.
So the Fuga is the same as an Mxx, more or less. Well, I've got a different model, it only has a 2.5l V6 (Fuga 250GT). I've recently had the CL illuminate, and have managed to extract error code 1031 off it.
This is the link to the Z and G car CL codes, are they assumed the same for M/Fuga? I assume so.
http://www.nicoclub.com/archives/350z-ecu-codes.html
Questions.
1) Can I assume that 1031 is indeed indicating one of these?
P1031 Air/Fuel Ratio Sensor Meter
P1032 Air/Fuel Ratio Sensor Meter
I note that this isn't actually indicating the sensors, which are these codes:
P1271 Air/Fuel Ratio Sensor 1
P1272 Air/Fuel Ratio Sensor 1
P1273 Air/Fuel Ratio Sensor 1
P1274 Air/Fuel Ratio Sensor 1
P1276 Air/Fuel Ratio Sensor 1
P1278 Air/Fuel Ratio Sensor 1
P1279 Air/Fuel Ratio Sensor 1
What precisely is the meter? Typically I'd assume it was a gauge, however as we don't have guages that cannot be it. Any extra information would be useful, and some sort of indication as to where I could find these Air/Fuel Ratio Sensor Meters would be amaze-balls!
Thanks in advance yo!
Nate
