06M4.5 wrote:needs more low
Prolly will drop it another 1/4 inch or so....
DoN_BLaZe34 wrote:Zags, i thought you had a BBK?
A closer side shot so we can see how flush the rears are would be nice..you're really holding out on the pics man lol
You're right, I had the AKebono calipers PC'd in Ferrri yellow. But that was on my 06 M35, however, I held on to my calipers, just need to source the rotors and ss lines again and they are going back on.
Will definitely posts some nicer/clearer pics soon.
mexillis wrote:I don't think the 10-12 mm would make it hit the little g37s caliper.
Yea, I didn't mock it up to make sure yet, bu also keep in mind that I reduced (increased?) offset on just the rears. The rear calipers are 2 pot? I believe, and are significantly smaller than the fronts. So I should have more than enough clearance. I believe I may also go with a 10mm spacer in front, just to push the rears out a little bit to be flush, or at least square with the rears.
