Fueltech FT550 on SRT20DET
SRT
Car: ???
Hi, I am trying to get a base map configured but unsure of some of the questions. I hope someone can shed some light on this for me.
RPM sensor type - is it a Hall/VR with pull up or VR internal reference or VR differential.
Is the RPM sensor edge Falling etc.
Does anyone know the Crank trigger pattern, crank index position etc.
I think the Cam sync sensor is a Hall/VR with pull-up and Falling edge but not sure.
The engine has stock intervals.
Any help would be gratefully received.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The sensors are easy to identify, two wires is a VR and three wires is a pulled-up Hall. For VR's, differential is if both wires go to the ECU, single-end is if one of the two is grounded. I'm not a tuner and I'll let other people help you with the rest of it.
SRT
Car: ???
Thank you very much. That’s a great help. 👍🏻
