Fueling question
StarPD
Car: 2005 Q45
Noy sure if this has been asked before, but here goes.
When I fuel up my 2005 Q45,I always top it off all the way until I can actually see the gas at the very top of the filler neck. This of course takes some time and careful dribbling in of the last bit to avoid overflow and spillage. I usually can get around 1.3 gallons more in this way, and calculating my mileage is accurate.
Does this compromise or create a problem with the fuel system?I note that when I open the gas cap to fuel up, I can't hear any pressure release like I used to on my '94 Q45t. The CEL has not appeared, and the car seems to run fine, with good power, throttle response, and fuel mileage. There is never any odor of gasoline from the car, inside, outside, or under the hood.
One of my concerns is that excess pressure in the fuel lines from topping off may be causing the injectors to bleed fuel into the cylinders when shut down overnight. This would wash the oil from the cylinder walls and lead to early and excessive cylinder wear, and eventually bearing /crankshaft erosion. I cannot detect and gasoline odor in the oil either, but it wouldn't take much leakage/seepage into the cylinders to create wear. Could this be the cause of no system pressurization when I open the gas cap?
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Probably not a good idea, Might get into the carbon filter canister.
StarPD
Car: 2005 Q45
Q45denver wrote:Probably not a good idea, Might get into the carbon filter canister.
Which would cause...?
qship96
Car: 1996 Infiniti Q45
I used to do it when I had my g20-in 147,000 miles of doing this,I never experienced a fuel system problem with that car-actually I never experienced any problem with that vehicle except a water pump and clutch replacement around 140,000 miles! hands down the most reliable car I have ever owned
StarPD
Car: 2005 Q45
And would it have to be replaced, or can it be drained?
StarPD
Car: 2005 Q45
Cost to replace?
Q45denver
1990 Infiniti Q45
Well, I would think if the carbon got saturated it would take a long time to evaporate and the car would likely not pass emmissions until then. There is a overflow hose on the bottom. I got a new/used one at the junk yard for $5 as mine seems to be plugged.
92Q45guy
Car: 92 Q45 93,000 miles / chain guides / transmission cooler / synthetic fluids / lots of love!
I do the same thing with my G50. So far no problems.
Q451990
92Q45guy wrote:I do the same thing with my G50. So far no problems.
Same here - no problem on two Q's and a Nissan Truck. The G is a pain to do, and I always end up spilling some down the side if I don't stop at the first or second automatic shut-off, so that's what I do. Usually Dana gets the gas for it anyway...
Heath
