oversteer180 wrote:Hmm, how hard is it to set up a tune with the safc? Should I even get an ecu tune if im going to be using the safc?
Yes, DEFINITELY get an ECU tune. The SAFC is good for minor adjustments. In case you don't know how it works, the SAFC just lies to the ecu about the amount of air coming in. Well, the ECU uses the amount of air (throttle position, rpm and O2 voltage) to determine a total theoretical pulsewidth which is what points to specific parts of the fuel and timing maps. The lower the amount of airflow, the more timing advance the ECU gives out. As you may guess, this can cause a problem with detonation if you lean out the safc too much.
A base rom for the ECU will directly change the injector size so you can make smaller adjustments with the SAFC.
